Cladding supported on edges for wind loading
I would like query the transfer of wind loads through claddings. Ideally, as shown in the attached picture, part of the wind loading would go to the foundation,at the bottom edge of the cladding - I modelled this edge as pin supported. It seems to me that even that doing this, it does not seem to attract any wind load, and the central beam supporting the cladding is getting much more load than it should. What would be the right approach if this is not valid as it seems?
Thank you,
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Currently you have supports under the columns as you cannot support cladding edge. You may consider defining a dummy beam at the bottom of the cladding between the columns and then add some nodes with supports along its length.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
ledinhchinh0409
Can you hide this object to proceed with the next job?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
No, you can't but what is the exact reason to 'hide' it?
Artur Kosakowski
ledinhchinh0409
I used to assign the wind load, then do other operations but was hindered although it was possible to hide some but difficult to work. Sorry for my poor english skills. Hi
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
My assumption is that you would like to hide some part of a model so that it is easier to work with its smaller part. In RSA you can't hide elements but you can select the part you want to work with and open it in a new window so that the other objects are not shown.
Artur Kosakowski
ledinhchinh0409
Hi.Artur.Kosakowski. I attached the calculation file. It seems that the floor is calculated in different directions. How can I adjust the calculation and calculate how to achieve the most accurate results. Sorry for my poor english skills. Thanks a lot!
