Cladding problem
Cladding problem
Message 1 of 9
Cladding problem
1- is it possible to choose how RSA should distribut the laod  for load applied on cladding?
2- the generated load fram cladding applied on the beam is as a trapez.. possible to change that to triangular?
3- why is a point load applied in the middle between to beams, distributed unsymmetric?
2- do I need to do something special for movingload on cladding? I have only applied the polyline on cladding.
Thanks.
Replies (8)
Message 2 of 9
Rafacascudo
1- Not sure if it is this what you´re asking but there´s 2 possible distributions . One way or 2 way.
2- Not that I know . Maybe Artur or Rafal ...
3- My opinion . Claddings are good for loads distributed on the whole cladding area . For partially distributed , linear and concentrated loads it can lead to very wrong results , because the distribution is based on tributary areas . So if the a concentrated load is inside an area , the whole force will go to just to the closest edge/side of the cladding . Better explained on the picture below
4-claddings work normally with moving loads , but be aware of what I explained above
Rafael Medeiros
Message 3 of 9
Ahaa, understand the problem about closest edge/side, but for moving load it should me allowed to choose whitch beam carry the load from  application plane selection? Does it then distrubute the load symmetric accourding to the position of the load?
Message 4 of 9
Rafacascudo
Well, did some tests and I found out some interesting things .
Claddings have no influence on the way the load is distributed to the beams . Load will be distributed proportional to the distance to the beams .
For a concentrated load ,it´s better to have 10 bars with 1m length , instead of a 10m beam . Below picture explains it better
You can see by the generated loads and the beams resulting bending moments that dividing the bar in 10 pieces produces a more realistic results scenario
The interesting thing is that a "shell type"  structure will not allow a vehicle with linear or surface loads if there is not a meshed panel.
But a Frame 3d structure type will allow a vehicle with linear load(no surprise here) . And even a surface load vehicle will generate loads on bars although the help file says that only a vehicle with concentrated and/or linear loads will generate loads for this structure type (bars)
Below , planar load vehicle on 3d frame structure type
claddings have no influence on this . Loads from vehicle will be generated even if cladding is deleted.
Rafael Medeiros
Message 5 of 9
Thanks, but for a concetrated lod between 2 beam.. should not robot distribute the load as a point load to these 2 beams?
Message 6 of 9
Rafacascudo
It depends much more on how your structure carry the load to the main girders. Load will only be totally concentrated on the main girders if there are transversal beams carrying the load to them. But then , You should select these transversal bars ,instead ,to be loaded on "application plane"
Play with "tolerance"  ,experiment it yourself. See the results , analyse!
http://help.autodesk.com/view/RSAPRO/2017/ENU/?guid=GUID-9DE9BED6-5813-4B3E-95CE-3ECA7AF6A83C
and also explore the help file always!! before coming here. Every single dialog window has a Help button.
Rafael Medeiros
Message 7 of 9
Yeah, have read a lot before asking here..
But when I changed the tolerance, the load between two beams are now distributed as a point load.. but only to one of the 2 beams. Do u know what I should do so the concentrated load between these 2 beams get distributed as a point load to these Two beams, and not only to one og them?
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Defining a vehicle with two half of the value loads with certain space between them and set the 'right' tolerance?
Artur Kosakowski
Message 9 of 9
Hmmm.. I have to do it for many cases so that will be difficult. Have Also to follow the eurocode.. no other method?
