Cladding Load Distribution
Message 1 of 8
Please refer to the attached model. The modelseems to be perfectly symmetric but is deflecting differing amounts on either side of the cantilevered section of roof. I may be related to the claddings distribution which is coming up with some strange results. I have checked how it the claddings are setup but cannot explain the issue?
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is waht you can get after replacing some claddings by triangular ones.
Rafal Gaweda
Message 3 of 8
Unfortunately this hasnt really solved the issue as the load is still not distributing the way we wanted. The main issue is that the load distribution is not happening symetrically - the structure is symetric and so we are getting some strange deflections which should not be real due to the way the load is distributing. After doing some reading it appears that this is a weakness of Robot for complex geometry which appears not to have a solution?
Message 4 of 8
Refaat
Hi
“The main issue is that the load distribution is not happening symetrically - the structure is symetric and so we are getting some strange deflections which should not be real due to the way the load is distributing.”
I think only you need to verify your model. I have attached two captures the first one with (non-symmetrical load distribution) while as the second one after correction your model (symmetrical load distribution).
As well I have attached the corrected model
I hope, I helped you
Refaat
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
None of these solutions is perfect.
Choose one of them or apply loads manually.
Rafal Gaweda
Message 6 of 8
Refaat
Dear Rafal
How do I choose one of them since there is a big different in the load distribution and the displacement values especially at the cantilever edge “as appear in captures of post (4).”?
I think the approximate solution will be that one in the second capture of post (4) after comparing the displacement values and (NTM) results with the case of applying loads manually.
Best Regards
Refaat
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear Refaat
My apologies, your model produces better results than mine.
Nick
Please use Refaat's model.
Rafal Gaweda
Message 8 of 8
Refaat
Dear Rafal
It was just attempt. I will stay always as one of your students. Smiley Happy
Thank you so much
Refaat
