Re. distribution on loads on cladding elements - see attached model and screen captures.
The load distribution appear to be different from a straight manual calculation for member 39.
1. Load of 0.9kPa on cladding, orientation local axis z, distributed to adjacent beams at 9m c/c would indicate a udl of 8.1kN/m, orientation local axis z of beam. Robot indicate a udl of 8.2kN/m on global z and -0.44kN/m on global y. That adds up to 8.21kN/m, orientation local z of beam.
2. The distribution of surface load on roof cladding to adjacent beam 39 is not accurate when superimposing the many generated loads.
Can anyone shed light why there are so many generated loads, some superimposed, from one load on cladding.
3. The symbol of load on cladding appear to be parallel to global z rather than local z. Load label/text is correct. - No screen capture on that, limit of 3 attached files.
4. I would like to avoid splitting the beam at locations where load changes as per previous advice from Stefano, to keep the model clean
I am rather fond of the availability of cladding element and load distribution as it considerably cuts down load modelling time, especially with wind loads to AS/NZS.
cheers
max
