Circular slab , symmetrical results
Could somene please help me with the attached file? I am modeling a circular slab (donut shape), to find the internal tension force when aplying a line load on the edge of the slab, pointing outward, around the circumference. The problem is that internal membrance force in the slab is not symetrical.
Also, how is it possible to extrude a circular wall connceted to the slab?
Thanks!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I am afraid I do not understand.
My results below:
Rafal Gaweda
Thank you for your help. Could you please specify the directions of the forces in the slab. XX and YY? Could you also upload the file you worked on, thanks!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Take a look at my screen shot.
Everything is out there.
Rafal Gaweda
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
