Robot Structural Analysis Forum
Welcome to Autodeskโ€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Changing members' sections
6 REPLIES 6
Muhammed.OPERA
506 Views, 6 Replies
When i model a building, i use primary sections for columns, beams, ... based on my experience and expectation for the internal forces that will be generated on these members. Then after modeling, i import the forces on members in Excel using Results Connect, then i design these members using some Excel sheets i made before. (I know that i can design in robot but i prefer to check my manual design on Robot).
After designing members, i need to change some members section in Robot model.
Is there's a link (API) between Robot and Excel, which i can use to change members' sections from excel despite instead of going back to Robot and change it manually.
Thank you ๐Ÿ™‚
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Tags (3)
6 REPLIES 6
Refaat
in reply to: Muhammed.OPERA
Muhammed.OPERA
in reply to: Refaat
Mr. @Refaat
I know that there's an API that i can use do define new sections in robot from Excel. I was asking whoever there's another which can assign section to list of bars/members from excel.
Thank you very much ๐Ÿ™‚
Facebook |LinkedIn
Hi @Muhammed.OPERA
Sure it is possible to write such macro. I am not aware of any similar already posted on forum.
If you do not want to try API by yourself ,maybe try Stefano's macro.
Rafal Gaweda
Thank you Mr. @Rafal.Gaweda
I really want to learn API but i don't know how to start.
If there's any tutorials, I'll be very thankful. ๐Ÿ™‚
Thank u for your time.
Facebook |LinkedIn
Hi @Muhammed.OPERA
Click on link in @Refaat 's post above.
Rafal Gaweda
Thanks Mr. @Rafal.Gaweda
Facebook |LinkedIn
