change the load case analysis type from linear to non linear
How to set the load cases as a non linear analysis case without considering the P-delta effect and the large displacement? since I have tension-only bracing members that I don't want the compression members to carry compression forces?
the settings that I have applied in the picture, did not change from the analysis type
Romanich
Hi @Anonymous ,
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Thank you. But I want to apply a seismic analysis and with defining this setting, a convergence errors come. I have just to do a simple seismic analysis with bracings have tension only , and I don't want to apply time history analysis. Is there any ways?
Romanich
Hi @Anonymous ,
Please check these topics:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Reducing-calculation-time/td-p/3875995
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/linear-or-non-linear-tension-only-bracing/td-p/3877573
Roman Zhelezniak
