Change of strength reinforcement
Hey guys. Do you know how to change the characteristic strength of the reinforcement in the RC beam calculations? It appears to there is only strength from 450-500 MPa where i want 550 MPa.
Thanks in advance.
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may find this slide from the 3rd Robot webinar helpful:
Artur Kosakowski
