Change member type parameters for selected bars
is there a way to change code group parameters for selected elements (columns in my case) (all at once)?
I figured out that it is possible to change properties type through "object properties" menu only when one element is selected!?
Regards!
@Anonymous Artur Kosakowski edited the topic from 'Change code group parameters for selected bars' for better findability
I see that it is possible to apply design parameters in steel/aluminium design module, but again one by one! I have a small model with 111 elements, but it's still a waste of time.
Capture.PNGRegards!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Assigning labels (including the member type with code parameters) is the same as for any other e.g. release. Just select the bars and assign the label:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Where can I find "member type" menu that's shown on your print screen!
Regards!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Design > Steel Member Design - Options > Code parameters
or
On the Steel Design layout.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
zeeblake
The RSA GUI is good, but I think that it would be even better if every feature could be managed only from one place: in this case, the functionality overlap between the member tab in the "Definitions" dialog box and the "Member type" dialog box is very confusing: it would be much cleaner and clearer to merge both dialog boxes in one. The same happens in other parts of the GUI. Anyway, RSA has a GUI much cleaner than other structural analysis software in the market.
