Cannot Set Service Class when doing Group Verification in Timber Design
Hello.
I am using the timber design function in RSA to do some member verification using round logs with a high moisture content. I have managed to get this to work using individual member verification but I would like to verfiy a whole group of members at once. Howeve when I go into the group tab in "Definitions" there is no "Parameters" option like there is in the Members tab so I cannot set the service class and it seems to default to class 1 or 2 which is no use to me. Is there another way to do this or do I have to verify individual members?
Thank you,
Hugh.
Here we go, answering my own question............
In case anyone has managed to misunderstand the timber design function in the same way that I did here's how you do it:
The Member verification option allows you to create a list of members sorted by various characteristics by simply pressing the "list" button to the right of the member number entry. This way you can verify all the members with a certain cross-section for example.
And yes, that should have been pretty obvious from the start.
