Cannot create cladding
Hi there,
when I try create a cladding robot reports the error that you can see in the attached file and, therefore, cannot create the cladding.
Do you what is the most likely cause for this?
Thanks a lot for your input.
Rodolfo
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Set Preferences as shown below
2. Save the file under a new name
3. Restart Robot
4. Open the saved file
5. Define a cladding
Artur Kosakowski
Thanks for the fast reply.
You have solved my problem. Thanks a lot!
Cheers,
Rodolfo
