Cannot change material if section has been created by code group design
juha.soini
juha.soini
I have noticed that if section is created automatically by code group design, the material is not possible to change later (i.e. material that has been specified to code group design settings is paired to that profile and cannot be changed later). Attached is Robot model that illustrates that problem. I am using RSA 2019 (version 32.0.2.6571).
Is it possible to somehow change material? I even tried via API and I didn't succeeded. I think this bug is quite frustrating.
If I create section manually by Sections -dialog, material can be changed later, although some default material has to be specified in dialog.
Would it be possible to create update to Robot that would give user to possibility change material freely without any dependencies to section (regardless of the method by which section was created)?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @juha.soini
I have recorded short video presenting how to change material using Section dialog or bar table.
I hope it will help to solve your issue
Material change
Krzysztof Wasik
