Can't see my nodes in Robot
I am trying to edit the position of a nodal load (of which I am not sure what the coordinates are). I would like to select the node that the point load is currently at, and view the "Object Properties" so that I can review the coordinates of the node. I can see the node numbers, but not the node points. "Hide nodes" is deselected in my display options, so I am not sure how to switch the node points back on. Can anyone advise how I can make my node points visible so that I can review and edit them?
Thank you
Rafacascudo
Check the load table to see which nodes have loads on them.
Also , try clicking on these buttons below
Rafael Medeiros
m_khanFJMB8
Community Visitor
Community Visitor
That worked, thanks
