Calculation won't perform Combination Check
Message 1 of 10
Can somebody help me?  I am trying to Calculate the member verification and the combinations won't work. It simply does not allow me to select it.
Replies (9)
Message 2 of 10
Hi Edward,
It is maybe worth taking a look at your model to see where the problem comes from.
Sara Santana Herrera
Message 3 of 10
Dear Edward,
Please send your model to help you,
Best regards,
Message 4 of 10
I'm trying to attach the model, but its not working.
Message 5 of 10
Romanich
Hi @Anonymous ,
Please zip your model or you can use cloud services like WeTransfer
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 6 of 10
I zipped the model.
What I can't do is when the steel member verification is generated the program will not check the combinations. It only checks the load cases.
Message 7 of 10
I have attached my model in the sixth response.
Message 8 of 10
I zipped it.
Message 9 of 10
I attached the model with a zip file.
Message 10 of 10
Hello Edward,
To code check your steel members using combinations, you first need to create these combinations. At the moment only the load cases DL1, DL2 and LL1 appear in the cases drop-down list (see attached image). To create combinations you can use the Manual and Automatic options from the Loads menu (see attached image).
Best regards,
