Calculation results
Calculation results
Calculation results
I have a heavy model that calculates in around 7hours. I have performed some small changes in the model but I can't see the results now. I have a results .RT file. Is there any way to see the old results although they are not updated?
Thanks.
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, there isn't unless you just open the original file on e.g. another computer. You may want to check if setting the the solver as Multi-threaded makes the calculations to be faster.
Artur Kosakowski
