Calculating M2 Emmedue Panels for structural floors and struct Roofs
Dear All,
For the more experience Structural Engineer, I would want to calculate M2 Emmedue Roofs and Floors using this panel. This M2 Emmedue system has been invented by Mr. Angelo Canderacci, and is considered one of the best construction building system in the world.
The emmedue panel, consists of a Polystyrene panel, with a 2.5mm mesh on both sides of the panel, and interconnected with 3mm connectors through the polystyrene, connecting to the mesh, and basically creating a rigid mesh.
For the walls, we shoot 3000 psi shotcrete on both sides of 3.5cm, in two layers(because you can't put 2 layers in one shot).
For Structural Floors we put the necesarry rebars on the bottom, brace them and we spray the underside with 2.5 to 3cm 3000psi shotcrete, and then we pour Concrete on the top. In between 5 to 8cm, depending on what the calculation gives.
Because the mesh, and the connecting rods, act like tiny I-beams, creating a sandwhich panel with polystyrene in the middle, basically cutting SELF WEIGHT by almost double, lets this panel span to 3.8 meters easily without any extra rebar mesh.
Question, how can I duplicate this mesh in Robot? Attached you will find all the information about the Panel. My next challenge is to calculate Low Slope Roofs and Structural Floors using ROBOT. There must be a way.
Kind Regards,
Greg
