Cable design, Instability (type 1), Matrix is not positive definite
5 REPLIES 5
676 Views, 5 Replies
Dear all,
I would design a cable system, which has several hanged masses between 2 columns. i just made a simplier case with 3 wires and a truss between them subjected to tension.
I don`t understand the warning that I got. I tried to solve the instability with releases (fix the Rz, because Uz has to be free), but it didn`t work. Also the matrix warning, because I thought it appears because of the buckling of the column, but when I made a solid 400mm diameter column, it still appears.
The main goal is to define the prestressing of the cables and I will have this kind of system with 7 cables, therefore I planned to use relative elongation and iterate until I find the right position of the pre-defined nodes, where the point loads has to be.
Please comment my model, I would really appreciate, especially because my first experiences with this forum was great, but so far I didn`t get any other help.
Thanks in advance!
5 REPLIES 5
vanvan11
now when i calc no warnings
is that ok? is warnings was problem
only thing i make to your model was to separate the upper cable in to 2 pcs couse point 2 which was instable to have conetions whit the upper cable
so i think that was the problem
tell me if my solution is ok for you
see my model
sry for my bad engl
in reply to: vanvan11
Dear Ivan,
Yes, your solution was right for this model, thank you! However this model was a simplier one, the real structure is like a wire chain with some bars to keep the distance between them.
I attached this model, because still there are the same error messages. I dont know why, because now every cable or wires are seperated respect to the nodes.
Rafal.Gaweda
Try with elongation relative -0,0001
Rafal Gaweda
in reply to: Rafal.Gaweda
Dear Rafa.Gaweda,
Thanks for the suggestion, I guess I have to "play" with this elongations to be good for all of the cables to reach more or less zero deflections for the specific nodes.
However, I have now another important issue, because I can not make a proper material definition for these cables. Picture attached.
I would set a smaller Young modulus for the cable due to I would take into consideration that it is more flexible at the installation, also it is a high tension cable, with a larger self-weight which I can not set! Why? (It is Robot 2014 version.)
Please disregard my previous message. I have solved the material issue.
