Building diaphrgam roof not working as expected
mcroftsRNARJ
mcroftsRNARJ
Community Visitor
Community Visitor
I have a multipitched roof with a shell diaphragm since not flat. The load is not going back to the steel members as expected, and there are various errors about the load not distributing. I have tried the merge/clean up to help fix the awkward geometry. Can someone help fix this model?
Rafacascudo
you cannot set a diaphragm on an inclined slab using RSA
From Robot manual
Note: Diaphragms can be generated only on horizontal panels in the XY plane
https://help.autodesk.com/view/RSAPRO/2024/ENU/?guid=GUID-F57A58F9-81AA-4410-84EA-6BFFD83D115C
also, check this
https://forums.autodesk.com/t5/robot-structural-analysis-forum/warning-the-load-has-not-been-distrib...
Rafael Medeiros
mcroftsASCNW
Observer
Observer
@Rafacascudo
I have followed procedure on this forum by adding shell (not ticked diaphragm action):
https://forums.autodesk.com/t5/robot-structural-analysis-forum/creating-a-diaphragm-roof/td-p/592582...
