Buckling mode as an initial deformation
antonio.lafuente
antonio.lafuente
Good afternoon
When considering a buckling mode as an initial deformation, can you select to which load cases does it apply and, if so, how?
Thanks in advance
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @antonio.lafuente
If buckling mode is selected as initial deformation, it works for all load cases and combinations defined in your model
You cannot define initial deformation for selected load cases/combinations only.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
