BMD
BMD
Martinagrech27
Message 1 of 12
BMD
Martinagrech27
When using the automatic self-weight function in robot the BMD is coming incorrect and the model isn't even working as though it is symmetrical.
Any ideas
Replies (11)
Message 2 of 12
EduardoMeruvia
Hi @Martinagrech27 ,
Would be easier to help if you can you upload your model.
If you can't upload your model due to privacy reason, some comments I would make is:
-Are your assumed end releases properly represented in your model, i.e. pinned, fix, rotational releases, etc.
-What elements are you using in your model? From the geometry of your model, seems like you might be using "cable" elements in combination with beam elements. Has the Joint between these two been checked as what is intended to be desgined?
-Is it a 2D or 3D model?
Message 3 of 12
Martinagrech27
Message 4 of 12
Simau
@Martinagrech27
Correct some errors:
- Select all PIPE_1 members and remove releases
- For non linear parameters
     Check PDelta and Large displacements,
    Check the 2 boxes Martix updadte...
M. Agayr
Message 5 of 12
Martinagrech27
@Simau thank you for your reply unfortunately after correcting these errors my model  still doesn't seem to be behaving as it should. The pipe members which I made tension only members don't seem to be having a similar effect to cables and only large moments in the two pylons seem to be appearing.
Message 6 of 12
Simau
@Martinagrech27
Share your new model for verification
M. Agayr
Message 7 of 12
Simau
@Martinagrech27
Sorry, the file a i attached previously was wrong.
Please find attached the good one.
I didn't try pipe members as cables
M. Agayr
Message 8 of 12
Martinagrech27
I am attaching my new model after making the amendments.
https://drive.google.com/file/d/12XiupFMyn5cUiLuT2hKAMJ9wf8keauIn/view?usp=sharing
Message 9 of 12
Simau
You didn't set non linear parameter for case 2 as i told you in message 4
M. Agayr
Message 10 of 12
Martinagrech27
@Simau These are set this way am I missing something else please ?
Message 11 of 12
Simau
@Martinagrech27
You have to set case 3 as auxiliary as you can't use moving loads  directly with non linear analisys.
File attached
M. Agayr
Message 12 of 12
Martinagrech27
@Simau  Yes thank you now the model seems to be working well although the influence line function isn't
