beam
beam
Message 1 of 13
beam
please tell me why the program does not see the beams ? Thank you very much.
Replies (12)
Message 2 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file please? Thank you.
Artur Kosakowski
Message 3 of 13
please
Message 4 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Correct excessive slab thickness
2. Increase sieze of profiles so that they support slab rather than vice versa
3. Add offset to beams
Artur Kosakowski
Message 5 of 13
and how can either get rid of the peaks which are formed at calonne? Thank you.
Message 6 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Increase sections of bars (or decrease thickness of slab).
Artur Kosakowski
Message 7 of 13
no, the plate rests on three beams, two walls, and in the model it turns out that she still leans on the column, otherwise the points were to be on the walls. So how to make the column not taken into account?
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
To "reproduce" your hand calcs approach where you as far as I understand assume beams as supports that cannot move vertically you need to prevent beams from bending (e.g. increase their sizes). The columns are relatively irrelevant.
Artur Kosakowski
Message 9 of 13
but if I can't change the section of the beam, that is, what is the solution?
Message 10 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
That's going to be your decision but perhaps you may re-think the static scheme of your structure. I'm sorry but this is as far as I'm able to help with my limited knowledge of your structure. Let's see if somebody else have some proposal for you Smiley Happy
Artur Kosakowski
Message 11 of 13
thank you very much for your help 😃
Message 12 of 13
DennisVDijk
The RSA programme does see the beam but they are to smale (not stiff enouf) to support the floor, see screenshot pdf.
Your floor is 2,25m thick as the steel beams have a height of 0,24m. your floor is almost 10times higher/thicker the the steel beams.
As you see in the screenshot, the fleildmoment is in the middle, downwards. If the beams took the load, the bending moment would be upwards!
The walls on both sides wil take the load now. The steel beams and columns are just hanging on the floor doing nothing!
You might reconseeder your model.
Good Luck!
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Message 13 of 13
with this I figured out. But the moments in the columns can't take
