Beam offsets and Tension only bracing
ByrnePM
ByrnePM
I have a large steel frame structrue made up of simple construction, therefore I want to model the connection of the primary beams to the columns with the appropriate offset to the column flanges in order to transfer the additional moment to the column.
I also want to use tension only X-bracing.
I have defined the offsets for my primary beams (of which there are many) and now I have placed all my X-bracing members in the structure (without any relases)
I now apply truss bar parameters, tension only, to all of my X-bracing.
I run the model and get prompted to turn on the DSC algorithm, so I do
I then run and get an error saying that the DSC algorithm is on and that I have offsets ?
What is the procedure now?
Do i have to go back and delete all offsets and replace with rigid links? And then, if i am changing column sizes, will the offsets(rigid links) change also?
Artur.Kosakowski
Autodesk Support
Autodesk Support
There has to be something more defined in your model as offsets and tension only bars will not force you to use DSC. The use of rigid link is not convenient as they do not adjust to size of columns. Could you attach the model (or its part) please?
Artur Kosakowski
