& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Is it possible to add a beam directly into the beam module using vba?
By changing its dimensions of the beam by vba. Thank you for your help
Hi @Anonymous
If I understood Your correctly, it can be done.
See example code below.
Dim Robapp As New RobotApplication Dim RC As RobotProjectComponent Set RC = Robapp.Project.ComponentMngr.Create(I_PCT_BEAM, "B1", "1") Dim IRCB As IRConcrBeam Set IRCB = RC.Data IRCB.Geometry.SpanNumber = 2 Dim IBS As IRConcrBeamSegment Set IBS = IRCB.Geometry.Span(1).segment(1) IBS.Dim(I_BSD_BEAM_SECTION_DIM_H1) = 1 IBS.Dim(I_BSD_BEAM_SECTION_DIM_B) = 0.5 Set IBS = IRCB.Geometry.Span(2).segment(1) IBS.Dim(I_BSD_BEAM_SECTION_DIM_H1) = 1 IBS.Dim(I_BSD_BEAM_SECTION_DIM_B) = 0.5
thank you very much it works!
is it possible to change the standard name of the beam P1, P2 ... in VBA?
thank you your code is already complete.
can you give an example to load the beam in the module beam in vba? thank you
HI @Anonymous
Example code
...... IRCB.Geometry.SpanNumber = 2 IRCB.LinearLoadsCount = 1 IRCB.LinearLoad(1).Case = 1 IRCB.LinearLoad(1).Nature = I_BLN_BEAM_NATURE_DEAD IRCB.LinearLoad(1).Spans.Add 1 IRCB.LinearLoad(1).Spans.Add 2 IRCB.LinearLoad(1).Value1 = 1000 Dim IBS As IRConcrBeamSegment ......
Thank you very much it works perfectly. you master very well the engineering. i am satisfied.
Hello Mr. Rafal trying to customize the VBA code above I have not found a possibility to call in VBA for some buttons in images attached. Is it possible to do that in VBA? Thank you very much for helping me with an example.
Hi @Anonymous
Everything what is available by API you can find expanding IRCB in my code
Hello Mr Rafal, yes I have already searched through your code. But it seems to be impossible to use the control buttons to frame in red on the image above in vba? Is there a vba guide for robot? thank you
Hi @Anonymous
So it means it is not implemented in API.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
