Beam (Lateral offset)
Message 1 of 11
What is the best way to model this situation? Its ok apply a lateral beam offset?
What consequences can bring applying the offset?
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
The offsets may cause additional axial force in the beams.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 11
Thanks Artur. This axial force affect the bending moment in a static analysis? Can I ignore the axial force for the determination of required reinforcement in the beam?
Perhaps, in the column the axial force cause an aditional bending moment?
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
See also:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/T-slab/m-p/3185418
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Beam-offsets/m-p/3332921
Artur Kosakowski
Message 5 of 11
AhmedZA
hi artur
is it possible to release axial force ( no instabilities after definition of releases )
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to release ux (only)  at one side of a bar element.
Artur Kosakowski
Message 7 of 11
HoshangMustafa
 Hi Artur
pipiyedu meant horizontal offset instead of vertical offset, i.e, eccentricity on columns.
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, that 's true. The rigid links should be in the horizontal plane indeed. Smiley Wink
Artur Kosakowski
Message 9 of 11
HoshangMustafa
Hi Artur
So, in this post:
Using horizontal offsets for RC beams don't influence values of internal forces. They don't cause large increase of the axial force (tension) and significant reduction of the bending moment.
Horizontal offset will increase eccentricity (and hence bending moment) on the columns instead.
Message 10 of 11
hi
sometime horizontal offset have no influence
I've worked a comparison between Rigid link and horizontal offsets as you can see the results are identical
Message 11 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Check axial forces and bending moments in the perpendicular to the displayed direction for the columns and compare them with the model where you neither have rigid link nor offsets.
Artur Kosakowski
