Hi!
Hopefully someone can help me with this problem that I don't understand.
I have a structure with an roof that looks like the following below where there are HEA 160 pillars and HEA 160 connecting between the pillars with an IPE 220 laying on top of the pillars. The roofing consisting of thin sheetmetal is laying on the IPE beams. The type of sections in the picture below continues for ~20m. The IPE beam is attached to the HEA beams with 4 screws on each pillar as in the picture below.
The IPE beams can be seen in the picture below.
Where the structure standing on the beams are new as can be seen in blue below.
Between the web of the IPE beam where the structure is standing I have added 2 UPE beams.
But when I try to run the buckling analysis I only get bad results on the stability.
With the following parameters.
a.
But if I change the buckling in Z and add an extra point in 0.4l I get the following results.
Should there be this large difference if I add an extra stabilizing in the Z-buckling on 0.4l? It is very far from where the load is attacking the structure.
Or am I going about this problem wrong since the beam is only attached on the flange?
