base plate fix support shell
vanvan11
Message 1 of 8
vanvan11
hi all
sorry can someone tell me is it my model correct
i try to model fix base plates with shells
10X
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may want to have a look at the bolt support definition and consider replacing UZ+ with UZ-.
Artur Kosakowski
Message 3 of 8
vanvan11
10x
can you tell me why i have z reactions with "+" and "-" in different comb when node support is uplift +-z
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure what you mean. If you have nodal supports with UZ+ you should have only  positive vertical reactions in these nodes. If UZ- only negative.
Artur Kosakowski
Message 5 of 8
vanvan11
"If you have nodal supports with UZ+ you should have only  positive vertical reactions in these nodes "
YES! but the results are not only positive vertical reactions why is that .That is my issue
or i miss something
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Leaving aside seismic cases (the model with uplift is not suitable for modal analysis) this should be like you said provided the analysis converged. Is this true for all simple load cases and combinations with the exception of the ones that include seismic?
Artur Kosakowski
Message 7 of 8
vanvan11
yes
thanks a lot
I understand now. support uplift is not used in seismic combinations because the results are approximate
So it must present seismic force as ordinary horizontal force and then I should be closer to the truth?
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes Smiley Happy
See also:
http://forums.autodesk.com/t5/robot-structural-analysis/uplift-elimination/m-p/3744231
Artur Kosakowski
