Base Connection settings
Michele100100
Michele100100
I would like to design and verify only the steel part of the connection (Eurocodes); I will do manually every thing happens in the concrete under the base plate: it's is correct to exclude this part of settings:
Thanks.
Stephane.kapetanovic
hi @Michele100100
Up to you, but you can also let checked steel checks
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Michele100100
