Bar releases and model verification
Hi!
I have been using linear release to make the slab pinned to the walls. It seems to work, but the only problem I face is that the concrete beam do have some moments at its ends. Could someone please help me verifying that the model is correct?
Thank you!
Mohammed_Ata
Dear,
Please, attach the model for verification
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
This effect is due to slab bi-directional stiffness. Compare with the unidirectional slab:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
