Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bar deflection results problem
3 REPLIES 3
555 Views, 3 Replies
I noticed a problem in some of my models when i run the verification for steel bars.
As you can see for load case 53 (as well as for all the other load cases) in the results preview for Trave_1 (as well as for all the other bars) it says Ratio (uz) 0.54, but in the results tab it says: uz =0.0 m and uz max = 0.0 m. The displacement in the bar is 0.7 cm as shown in "Exact deformation for bars".
How is it possible?
3 REPLIES 3
Artur.Kosakowski
Could you attach the model please?
Artur Kosakowski
in reply to: Artur.Kosakowski
Thank you for your quick reply, here's the model
Artur.Kosakowski
Mind the precision of the display of the units. You may want to set them as the one you use in Robot so that you can easier compare the results.
Artur Kosakowski
