Automatic Load Combinations don't generate any combinations
tomislavmartinovic16
Message 1 of 9
I have a really simple assignment to do, it's a cambered timber beam, and I wanted to do the statics part in Robot. For some reason, when I try to generate automatic load combinations, it doesn't work. I am on Windows and using Robot 2021. Please help! 😁
I also tried the solution where they suggest deleting .rlg files but it doesn't work...
Replies (8)
Message 2 of 9
HoshangMustafa
Hi
Try calculating the analysis.
Message 3 of 9
Yup, tried it, nothing happens, it just calculates the cases on their own (DL1, LL1, etc.)
Message 4 of 9
Simau
Could you share your model
zip it before
M. Agayr
Message 5 of 9
Here it is!
Message 6 of 9
Simau
Hi @tomislavmartinovic16
Perhaps you didn't follow all necessary step to generate combinations
Model with comb attached
M. Agayr
Message 7 of 9
Can you please explain the procedure? I need to use the Danish EC annex so I can try it myself. I was following the instructions on the Autodesk Knowledge website, maybe there's something else I needed to do?
Message 8 of 9
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Please refer to this video
Krzysztof Wasik
Message 9 of 9
Thank you all guys for the help, I made it work now!
