Automatic Buckling lenght RSA calculation
Hi all,
I have some question regarding how RSA calculate buckling length with automatic procedure. I know that it assumes the hypothesis of EN 1993, annex E, however I do get some problems when I perform my analysis. In the picture attached I extrapolated a part of my structure, where you can see, basically, my constraint. The beams are fixed to the column (that is continuous in its length) too in both direction. Now here's my first questione. When I use the automatic procedure with the column fixed at the base, I get similar results with automatic one and buckling coefficient with 6 members. Now, is it correct to not assign entry n°3 and 6 (the one regarding the column above and below) if my column is continuous over the storeys?
When, instead, I choose to use an hinge at the bottom of my column, with the automatic procedure my column is unstable along z-axis. Using the buckling coefficient with 6 members, the column is stable again. Is it a problem regarding the fact RSA wants a fixed column when using automatic procedure or maybe is it linked to the fact my column is continuous? (Indeed I also tried splitting my column where the beams join and the result is correct both with fixed and hinged condition.
Thanks in advance for any answer 🙂
