AUTODESL ROBOT WINDOW FREEZES
ALEXTHAINESE
Message 1 of 1
ALEXTHAINESE
hi all
after i ran a non linear analysis of my model that contains 400 load combonations , i then tried to assign steel parameters for objects assigned as beams , colums  to the bar elements in my model .
when i closed the steel parameter window , autodesk robot freezes and thereby i can dont any operation . if i click on window a background sound appears.
check   the video attached .
the only option left for me is to close it forcefully  , but then i will lose all my results.
what should i do
Replies (0)
