AS1170 Automatic Load Combinations
andrey
andrey
I am generating automatic load combination based on a number of different wind loads generated in Robot.
When I review the combination table to see the definitions it appears to add all the cases together.
I do not think that this is correct, is there a way to fix this?
Cases 10 to 17 are wind load from different directions and as you can see they are added together which cannot be the case.
Simau
Hi @andrey
When selecting wind load cases, use  "or(excl)"
M. Agayr
andrey
Hi Simau,
thanks for getting back to me.
Excellent thanks worked perfectly now 1 wind load per combination
ezzeldien_alfeqy
how we can get the wind to be reversable automatically, how can RSA repeat same combo including wind but with (-1*W) same as he do in seismic load case/group without making new load case called W-x or W-y?
Simau
Hi @ezzeldien_alfeqy
In seismic load cases négative Newmark combiations are reated automatically, but it's not possible with wind combinations.
A workaround is to create manually a combination W(-)= -1*W(+), then in the automatic combination creation, select the W(+) cases and the W(-) combinations.
M. Agayr
ezzeldien_alfeqy
Accepted solution, Thank you
