ARS2016 - Missing
ARS2016 - Missing
Refaat
Advisor Advisor
ARS2016 - Missing
Refaat
Dear colleagues
How can solve these matters :
1. File command is missing from Menu … Capture 00
2. Material properties according to British is also missing … Capture 01
Thanks in advance
Refaat
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to rename your CfgUsr folder
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2016\CfgUsr\
Artur Kosakowski
Rafal.Gaweda
Autodesk Support
Autodesk Support
Refaat
Dear Rafal
Thank you for your response. Actually, I tried with this solution before adding this post. But unfortunately, it doesn't work.
Refaat
Rafal.Gaweda
Autodesk Support
Autodesk Support
Reinstall Robot.
Rafal Gaweda
Refaat
Dear Rafal
Only the British material database is still missing after reinstall Robot (attached capture).
Please, any other suggestion?
Knowing that even (SP4) has been installed.
Regards
Refaat
Rafal.Gaweda
Autodesk Support
Autodesk Support
Replace
"c:\ProgramData\Autodesk\Structural\Common Data\2016\Data\Mate\Rmat044.xml"
and
"c:\Users\%username%\AppData\Roaming\Autodesk\Structural\Common Data\2016\RMAT044.xml"
and
"c:\Users\All Users\Autodesk\Structural\Common Data\2016\Data\Mate\Rmat044.xml"
by the file attached
Rafal Gaweda
