Apply Area Load in specific area.
What is the best way to apply area loads to a series of floor or roof beams?Capture.PNG
Maybe i have not understood your question but if you want to load secondary beams the easiest way is to use claddings:
On the top of the Robot Canvas Geometry --> claddings
It's a Surface with no weight that distributes the load on secondary beams using influence area:
If you want to look on how Robot distributes loads on you secondary beam then:
Right click on Robot Canvas --> Display --> Loads --> Forces Generated Automatically
Rafacascudo
Create claddings (geometry/claddings) and apply area loads as it was a regular panel. Loads will be distributed on one or 2 directions on the beams you choose (Geometry/additional atributes/Load distribution- options) according to the trapezoidal/triangular method
Rafael Medeiros
CaioSaporito
Hi @Anonymous!
See this autodesk video that illustrates what @Rafacascudo and @Anonymous said.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Wow. Thank you all ( @CaioSaporito @Rafacascudo @Anonymous ) for your contribution Smiley Happy
Artur Kosakowski
