API to extract Filepath and Filename in C#
GGB.BHB
GGB.BHB
Hi
I have tried to use the API guide to put together some C# code to call the file path and name of the active model.  Unfortunately I cannot get it to work 😞
Please can you show me how it should be done?
Many thanks
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @GGB.BHB
Once I made it this way:
            string FN = Robot.robApp.Project.FileName;
            string Dir = FN.Substring(0, FN.LastIndexOf("\\"));
            string FileName = FN.Substring(FN.LastIndexOf("\\")+1);
Rafal Gaweda
GGB.BHB
Thank you.  This is what I tried with what you sent through.  It seems to almost be there but I don't know how to assign IRobotProject ROBOT to the current open instance of robot!  How do I do that?
Many thanks
public static void GetROBOTfilename(RobotApplication robot, out string filename)
filename = "BLANK";
IRobotProject ROBOT;
string FN = ROBOT.FileName;
string ModelFilePath = FN.Substring(0, FN.LastIndexOf("\\"));
filename = FN.Substring(FN.LastIndexOf("\\") + 1);
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @GGB.BHB
API interface is automatically linked with only one robot (no matter how many robots is running) = the last one opened. You can not change it.
You can load the project by API.
Rafal Gaweda
GGB.BHB
Hi Rafal
Thank you for explaining that.  Have now got the code to run up to a point but it doesn't appear to get the name of the file.  The 'RobotOM,IRobotProject.FileName.get returned =null' although it seems to have got the Project and the RobotApplication - See highlighted red box in screen shot attached
Any suggestions?
Many thanks
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @GGB.BHB
Check how many Robots is running...
            if (Process.GetProcessesByName("Robot").Length > 1)
                MessageBox.Show("More than 1 Robot is running");
https://docs.microsoft.com/en-us/dotnet/api/system.diagnostics.process.getprocesses?view=netframewor...
Rafal Gaweda
GGB.BHB
Hi Rafal
That seems to have sorted it Smiley Happy
The code now looks like this and it works!
Thank you
public static void GetROBOTfilename(RobotApplication robot, out string ModelFilePath, out string ModelFileName)
if (System.Diagnostics.Process.GetProcessesByName("Robot").Length > 1)
{ Console.WriteLine("More than one instance of Robot is running. CLOSE AND RESTART"); }
else { Console.WriteLine("Single instance of Robot is running"); }
string FN = robot.Project.FileName;
ModelFileName = FN.Substring(FN.LastIndexOf("\\") + 1);
