(API) Soil load and moving loads
Stephane.kapetanovic
Mentor Mentor
Message 1 of 1
A copy of a popular discussion thread from 2014
2/25
Dim Cas As RobotMobileCase
Dim Route As RobotMobileCaseRoute
Dim VData As RobotVehicleData
Dim PlineGeometry As RobotGeoPolyline
Set PlineGeometry = Robapp.CmpntFactory.Create(I_CT_GEO_POLYLINE)
Dim Segment As New RobotGeoSegment
Dim Object As RobotObjObject
Set Segment = Robapp.CmpntFactory.Create(I_CT_GEO_SEGMENT_LINE)
Segment.P1.Set 0, 2, 0
PlineGeometry.Add Segment
PlineGeometry.Initialize
Segment.P1.Set 10, 2, 0
RouteNumber = 13
Set Object = Robapp.Project.Structure.Objects.Create(RouteNumber)
Object.Main.Geometry = PlineGeometry
Object.Initialize
Object.Update
Set Cas = Robapp.Project.Structure.Cases.CreateMobile(Robapp.Project.Structure.Cases.FreeNumber, "Moving PN", I_CN_PERMANENT)
Set Route = Cas.GetRoute
Route.Geometry = RouteNumber
Dim Fac As RobotMobileCaseSegmentFactors
Set Fac = Route.GetFactors(1)
Fac.VL = 1
Fac.VR = 1
Route.SetFactors 1, Fac
Route.LoadDirection.Set 0, 0, -1
Route.Step = 1
Cas.SetRoute Route
' przypadek z pojazdem  z bazy standardowej
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "Pojazd S - klasa E")
Set VData = VLabel.Data
VData.LoadFromDBase "Pojazd S - klasa E", "PN1030"
Robapp.Project.Structure.Labels.Store VLabel
Cas.Vehicle = "Pojazd S - klasa E"
' przypadek z pojazdem  z bazy uzytkownika
Set Cas = Robapp.Project.Structure.Cases.CreateMobile(Robapp.Project.Structure.Cases.FreeNumber, "Moving RG", I_CN_PERMANENT)
Fac.VL = 1
Fac.VR = 1
Route.Step = 1
Cas.SetRoute Route
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "RG")
VData.LoadFromDBase "RG", "RG"
Cas.Vehicle = "RG"
' przypadek z pojazdem nie z bazy
Set Cas = Robapp.Project.Structure.Cases.CreateMobile(Robapp.Project.Structure.Cases.FreeNumber, "Moving Load Case", I_CN_PERMANENT)
Fac.VL = 1
Fac.VR = 1
Route.Step = 1
Cas.SetRoute Route
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "RG111")
Cas.Vehicle = "RG111"
22/25
 ' vmilRoute is already create
     iLC = iLC + 1
        Dim C1_SR As RobotMobileCase
        Set C1_SR = robapp.Project.Structure.Cases.CreateMobile(iLC, "C1 Semi Remorque", I_CN_EXPLOATATION)
        'creation des vehicules
            'C1_SR
        Dim C1_SRlab As RobotLabel
        Dim C1_SR_1data As RobotVehicleData
        Dim C1_SR_2data As RobotVehicleData
        Dim C1_SR_3data As RobotVehicleData
        Dim C1_SR_4data As RobotVehicleData
        Dim C1_SR_1 As RobotVehicleLoad
        Dim C1_SR_2 As RobotVehicleLoad
        Dim C1_SR_3 As RobotVehicleLoad
        Dim C1_SR_4 As RobotVehicleLoad
        Set C1_SRlab = robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "C1 SR")
        Set C1_SR_1data = C1_SRlab.Data
        Set C1_SR_1 = C1_SR_1data.Loads.New
        C1_SR_1.Type = I_VLT_SURFACE
        C1_SR_1.F = Val("48") / (3.2 * 5.44) * 1000
        C1_SR_1.X = 0
        C1_SR_1.S = 0
        C1_SR_1.DX = 5.44
        C1_SR_1.DY = 3.2
        Set C1_SR_2data = C1_SRlab.Data
        Set C1_SR_2 = C1_SR_2data.Loads.New
        C1_SR_2.Type = I_VLT_CONCENTRATED
        C1_SR_2.F = Val("45") * 1000
        C1_SR_2.X = 9.22
        C1_SR_2.S = 2
        Set C1_SR_3data = C1_SRlab.Data
        Set C1_SR_3 = C1_SR_3data.Loads.New
        C1_SR_3.Type = I_VLT_CONCENTRATED
        C1_SR_3.F = Val("45") * 1000
        C1_SR_3.X = 10.58
        C1_SR_3.S = 2
        Set C1_SR_4data = C1_SRlab.Data
        Set C1_SR_4 = C1_SR_4data.Loads.New
        C1_SR_4.Type = I_VLT_CONCENTRATED
        C1_SR_4.F = Val("30") * 1000
        C1_SR_4.X = 13.78
        C1_SR_4.S = 2
        robapp.Project.Structure.Labels.Store C1_SRlab
        'attribution des vehicules et chemin C1_SR
        Set vmilRoute = C1_SR.GetRoute
        vmilRoute.Geometry = RouteNumberVmil
        Dim FactSeg As RobotMobileCaseSegmentFactors
        Set FactSeg = vmilRoute.GetFactors(1)
        FactSeg.VL = 1
        FactSeg.VR = 1
        vmilRoute.SetFactors 1, FactSeg
        vmilRoute.Step = 1
        vmilRoute.LoadDirection.Set 0, 0, -1
        C1_SR.SetRoute vmilRoute
        C1_SR.Vehicle = "C1 SR"
23/25
Dim PlineGeometryV1 As RobotGeoPolyline
            Set PlineGeometryV1 = robapp.CmpntFactory.Create(I_CT_GEO_POLYLINE)
            Dim SegmentV1 As RobotGeoSegment
            Dim ObjectV1 As RobotObjObject
            Dim RouteNumberV1 As Long
            x0 = 0
            For i = 0 To UBound(ltrav, 1)
                Set SegmentV1 = robapp.CmpntFactory.Create(I_CT_GEO_SEGMENT_LINE)
                SegmentV1.P1.Set x0 - (yV1 + 1.5) * Tan((biais - 100) * WorksheetFunction.Pi / 200), y0 + yV1 + 1.5, z0
                PlineGeometryV1.Add SegmentV1
                PlineGeometryV1.Initialize
                x0 = x0 + ltrav(i)
            Next i
            RouteNumberV1 = tdc.Objects.FreeNumber
            Set ObjectV1 = robapp.Project.Structure.Objects.Create(RouteNumberV1)
            ObjectV1.Main.Geometry = PlineGeometryV1
            ObjectV1.Initialize
            ObjectV1.Update
For k = 0 To PlineGeometryV1.Segments.Count - 1 'pour que le vehicule passe sur tous les segments du polyligne
            Set FactSeg = v1Route.GetFactors(1)
            FactSeg.VL = 1
            FactSeg.VR = 1
            v1Route.SetFactors k + 1, FactSeg
            v1Route.Step = 1
        Next k
        v1Route.LoadDirection.Set 0, 0, -1
        LM1_TS1.SetRoute v1Route
        LM1_TS1.Vehicle = "LM1 TS1"
.25
Add this command :
x = VData.Loads.Count
While x <> 0
VData.Loads.Delete (x)
x = x - 1
Wend
After the line :
If (Cells(Row, 3).Value = "Vehicle name") Then
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, Cells(Row, 4).Value)
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Replies (0)
