(API) Select all panels for mesh generation
Message 1 of 8
Hi!
I would like to select all panel objects, generate mesh and freez it.
IRobotObjObject Panelx;
Panelx = (IRobotObjObject)robApp.Project.Structure.Objects.GetAll(); - unfortunately it can not be converted to IRobotObjObject.
Panelx = (IRobotObjObject)robApp.Project.Structure.Objects.Get(1); - unfortunately I must define variable int that selects only plates and mesh will be generated plate by plate.
Panelx.Mesh.Generate();
Panelx.Mesh.Freeze = true;
Is there a way to select all panels at once or I should use .Get(i) and generate mesh plate by plate?
Best Regards,
Daniel
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Objects are all geometrical model elements except nodes so you have to create correct selection \ collection limited to panels only.
    Dim RSelection As RobotSelection
    Set RSelection = RobApp.Project.Structure.Selections.Create(I_OT_PANEL)
    RSelection.FromText "all"
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSelection)
then play with panels from this collection
Rafal Gaweda
Message 3 of 8
Thank you!
Message 4 of 8
Is there a way to modify the attributes of numerous panels all at once? For example I want to select all my panels, and then apply .Main.Attribs.Meshed = True and .SetLabel and .Initialise, but I am not able to do this while using the .GetMany function, just .Get for an individual panel. The reason I need this is I am creating thousands of panels and applying the attributes one at a time in a loop takes a long time and I am trying to reduce this. Thank you in advance!
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
No
and .SetLabel
RobApp.Project.Structure.Objects.SetLabel()
and .Initialise,
No
Rafal Gaweda
Message 6 of 8
Hi Rafal,
Thank you very much for your reply.
I am using VBA and the current code I have for assigning the panel thickness is;
Dim Panel as RobotObjObjectServer
Set Panel = RobApp.Project.Structure.Objects
Dim ActivePanel as RobotObjObject
Set ActivePanel = Panel.Get (i) 'looping through from i = 0 to the number of panels
ActivePanel.SetLabel XXX,XXX 'with the required thickness label
What I would like instead is to have something like:
Set ActivePanel = Panel.GetAll
so all panels are set the same label in one line of code, but I don't quite understand how to make this work. Would you be able to point me in the right direction?
Thank you
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Example:
    Set RSelection = RobApp.Project.Structure.Selections.CreateFull(I_OT_PANEL)
    RobApp.Project.Structure.Objects.SetLabel RSelection, I_LT_PANEL_THICKNESS, "MY_THICKNESS"
Rafal Gaweda
Message 8 of 8
Hi Rafal,
That has worked a charm. As always, thank you so much for your support 🙂
