API points on calc element
AbelSV78
Message 1 of 12
AbelSV78
Dear all,
we are triying to extract data from a bar in a model with VB.net. For example, we have obtained Smax in a bar, but only in determinate points, NOT THE MAXIMUM. Could you indicate me the variable to obtain this maximum?
See attached file, we can obtain data from first and third option, but not with second (this the one we need).
Thank you in advance
Best regards
Replies (11)
Message 2 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Not implemented
You have to write such function by your own, if you need it.
Rafal Gaweda
Message 3 of 12
AbelSV78
Dear Rafal, all...
we continue working on bar stresses. Is it possible to know (for one bar, one load case) the position of maximum S min(MY) ? Could you give me the varialbe for VB.net and how to use it?
Thank you so so much in advance, regards.
Message 4 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use RobotExtremeResultServer
Rafal Gaweda
Message 5 of 12
AbelSV78
We are trying this, but it doesn't work. Could you indicate us how to apply?:
Dim robApp As RobotOM.IRobotApplication = New RobotOM.RobotApplication
        Dim Bar As RobotOM.IRobotBar
        Dim BarCol As RobotOM.RobotBarCollection
        Dim CasCol As RobotOM.RobotCaseCollection
        Dim caso As RobotOM.IRobotCase
        Dim BarExtremeStressServer As RobotOM.RobotExtremeResultServer
        CasCol = robApp.Project.Structure.Cases.GetAll()
        BarCol = robApp.Project.Structure.Bars.GetAll()
        For i = 1 To BarCol.Count
            For ii = 1 To CasCol.Count
                caso = CasCol.Get(ii)
               Bar = BarCol.Get(i)
                BarExtremeStressServer = robApp.Project.Structure.Results.Bars.Stresses
                Dim ExtremeParams As RobotOM.RobotExtremeParams
                ExtremeParams = robApp.CmpntFactory.Create(RobotOM.IRobotComponentType.I_CT_EXTREME_PARAMS)
                ExtremeParams.BarDivision = 100
                ExtremeParams.Selection.Set(RobotOM.IRobotObjectType.I_OT_BAR, Bar)
                ExtremeParams.Selection.Set(RobotOM.IRobotObjectType.I_OT_CASE, caso)
                ExtremeParams.ValueType = RobotOM.IRobotExtremeValueType.I_EVT_FORCE_BAR_FX
                Dim MaxValue As Double = robApp.Project.Structure.Results.Extremes.MaxValue(ExtremeParams).Value
                Dim MaxValuePosition As Double = robApp.Project.Structure.Results.Extremes.MaxValue(ExtremeParams).Position
                Dim MinValue As Double = robApp.Project.Structure.Results.Extremes.MinValue(ExtremeParams).Value
                Dim MinValuePosition As Double = robApp.Project.Structure.Results.Extremes.MinValue(ExtremeParams).Position
            Next ii
        Next i
Thank you so much
Message 6 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
You try to get Stress but ask for force : I_EVT_FORCE_BAR_FX
Rafal Gaweda
Message 7 of 12
AbelSV78
Sorry about confussion. We have obtained the maximum value and its position, but only for selection bars, this is:
            Bar = BarCol.Get(i)
                ExtremeParams.Selection.Set(RobotOM.IRobotObjectType.I_OT_CASE, case)
                ExtremeParams.ValueType = RobotOM.IRobotExtremeValueType.I_EVT_STRESS_BAR_SMAX_MY
                Dim My_Max As Double = robApp.Project.Structure.Results.Extremes.MaxValue(ExtremeParams).Value
                Dim My_Pos As Double = robApp.Project.Structure.Results.Extremes.MaxValue(ExtremeParams).Position
                MsgBox(System.Math.Round(My_Max / 1000000, 2))
                MsgBox(System.Math.Round(My_Pos, 2))
Next ii
We are trying to obtain from all bars in model, but we can't (only for selected bars). Can you help us???
Thank you so much
Message 8 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Bar and caso (not "case") in ExtremeParams.Selection.Set  should be selections, not objects
"Next i" line is missing but I think it is not the point here.
Rafal Gaweda
Message 9 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example code (update selection according to your needs)
    Dim REV As RobotExtremeValue
    Dim Params As RobotExtremeParams
    Set Params = New RobotExtremeParams
    Params.BarDivision = 101
    Dim rs As RobotSelection
    Set rs = RobApp.Project.Structure.Selections.CreateFull(I_OT_BAR)
    Dim rsc As RobotSelection
    Set rsc = RobApp.Project.Structure.Selections.CreateFull(I_OT_CASE)
    Params.Selection.Set I_OT_BAR, rs
    Params.Selection.Set I_OT_CASE, rsc
    Params.ValueType = I_EVT_STRESS_BAR_SMAX
        Set REV = RobApp.Project.Structure.Results.Extremes.MaxValue(Params)
            aaa = REV.Position
            ccc = REV.Case
            ddd = REV.Value
            eee = REV.Bar
Rafal Gaweda
Message 10 of 12
AbelSV78
With this solution, we do not obtain any response from computer, there is no error but there is no solution, compilation is blocked.
We have this code and it works for one bar, for one load case:
Bar = BarCol.Get(i)
For iii = 0 To BarLong Step 1
BSD = BarStressServer.Value(BarNumber, CasoNumber, (iii / BarLong) )
BarSmax = System.Math.Round(BSD.Smax / 1000000, 2)
                    BarSmin = System.Math.Round(BSD.Smin / 1000000, 2)
                    BarSmaxMy = System.Math.Round(BSD.SmaxMY / 1000000, 2
                    BarSmaxMz = System.Math.Round(BSD.SmaxMZ / 1000000, 2)
                    BarSminMy = System.Math.Round(BSD.SminMY / 1000000, 2)
                    BarSminMz = System.Math.Round(BSD.SminMZ / 1000000, 2)
                    BarFxSx = System.Math.Round(BSD.FXSX / 1000000, 2)
                    BarTy = System.Math.Round(BSD.ShearY / 1000000, 2)
                    BarTz = System.Math.Round(BSD.ShearZ / 1000000, 2)
                    BarT = System.Math.Round(BSD.Torsion / 1000000, 2)
Next iii
Next ii
Next i
We need to obtain the maximum stress for all bar and each load case.
Thank you again
Message 11 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Your CaseCol is empty \ null \ not set
My example code for finding max stress bar out all bars for each load case
    Dim rsc_single As RobotSelection
    Set rsc_single = RobApp.Project.Structure.Selections.Create(I_OT_CASE)
    Dim CasCol As RobotCaseCollection
    Set CasCol = RobApp.Project.Structure.Cases.GetAll
    For i = 1 To CasCol.Count
    rsc_single.FromText Str(CasCol.Get(i).Number)
    Params.Selection.Set I_OT_CASE, rsc_single
            MsgBox ("BAR= " + Str(REV.Bar) + " " + " Case= " + Str(REV.Case) + " Pos = " + Str(REV.Position) + " Value = " + Str(REV.Value))
    Next i
Rafal Gaweda
Message 12 of 12
AbelSV78
Hi again, finally it works:
Dim REV As RobotOM.RobotExtremeValue
        Dim Params As RobotOM.RobotExtremeParams
        Params = New RobotOM.RobotExtremeParams
        Dim rs As RobotOM.RobotSelection
        rs = robApp.Project.Structure.Selections.CreateFull(RobotOM.IRobotObjectType.I_OT_BAR)
        Dim rsb_single As RobotOM.IRobotSelection
        rsb_single = robApp.Project.Structure.Selections.Create(RobotOM.IRobotObjectType.I_OT_BAR)
        Dim rsc_single As RobotOM.RobotSelection
        rsc_single = robApp.Project.Structure.Selections.Create(RobotOM.IRobotObjectType.I_OT_CASE)
        For ii = 1 To BarCol.Count
                rsc_single.FromText(Str(CasCol.Get(i).Number))
                rsb_single.FromText(Str(BarCol.Get(ii).Number))
                Params.Selection.Set(RobotOM.IRobotObjectType.I_OT_BAR, rsb_single)
                Params.Selection.Set(RobotOM.IRobotObjectType.I_OT_CASE, rsc_single)
                REV = robApp.Project.Structure.Results.Extremes.MaxValue(Params)
                MsgBox("BAR= " + Str(REV.Bar) + " " + " Case= " + Str(REV.Case) + " Pos = " + Str(REV.Position) + " Value = " + Str(REV.Value))
            Next i
        Next ii
Thank you so much.
