API - Panel Cuts
API - Panel Cuts
API - Panel Cuts
Is it possible to get the integral value of a panel cut using API? If yes, could you please write the syntaxe?
Thank you.
David
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Panel cut Integral value is always displayed when panel cut diagram is created by API
Rafal Gaweda
Thank you for your reply.
Yes, I know that.
My intention is to do a macro that gets the integral value and then divide it by the cut length automatically without using a calculator.
Is it possible?
David
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
No way thru API.
You need to do that manually
Rafal Gaweda
Ok! Smiley Sad
Do you think that in future versions, it would be possible incorporate that "property" in an API object?
David
miguelmachadoecosta
Hi @Rafal.Gaweda,
Is it possible already with RSA 2021? I have a plugin in SAP2000 which allows me to check the total forces and per unit lenght for multiple combinations for a cut:
I'm in the process of evaluating whether to switch from SAP2000 to RSA. Would I be able to do something similar in RSA?
mnggBA5CL
Observer
Observer
can you tell me the syntax for that just to display the integral value in excel for different panel cuts created through API?
