(API) node number
(API) node number
Message 1 of 8
(API) node number
I can not get the correct node number if the node numbering is not regular.
Dim RN As RobotNodeCollection
Dim inode As IRobotNode
Dim nodeid as integer
Set RN = robapp.Project.Structure.Nodes.GetAll
Set inode = RN.Get(11)
nodeid = inode.count
the nodeid is not correct if the node numbering is not regular. The 11th node is 15 in my model but in API it gives me 11.
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
HI @Anonymous
I think You should use it in correct way:
nodeid = inode.Number
So example loop to get all nodes numbers
for i=1 to RN.Count
Set inode = RN.Get(i)
next i
Rafal Gaweda
Message 3 of 8
still does not work.  "inode.Number" still gives me  11 for 11th node although the correct id is 12.  I attached the numbers of my nodes.
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
See below
Rafal Gaweda
Message 5 of 8
Thanks for your answer but in my code it does not work. I am using v15.
for 11th node it still gives 11 as the node number . see my code in the attachment.
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
See below
Rafal Gaweda
Message 7 of 8
then it means node 11 may be calculation node in my model. Is nodes.Getall effective also for calculation nodes ?
because in my node table there is no node 11. I suspect it is a calculation node.
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Yes.
Rafal Gaweda
