(API) New Window
chjpcoi
(API) New Window
chjpcoi
Hello everyone
I create a new view and want to select some elements from the original view to the new view. But I have the problem that other unselected elements of the parent view are also selected (screenshot Pic1), code below:
RobotStructure struc = rbApp.Project.Structure;
RobotSelection rselection = struc.Selections.Get(IRobotObjectType.I_OT_OBJECT);
rselection.FromText(dicStories[item]);
IRobotView3 viewRobot = (IRobotView3)rbApp.Project.ViewMngr.CreateView(IRobotViewType.I_VT_STANDARD);
viewRobot.Selection.Set(IRobotObjectType.I_OT_OBJECT, rselection);
viewRobot.Visible = 1;
viewRobot.Redraw(0);
viewRobot.Projection = IRobotViewProjection.I_VP_XY;
Can you help me?
Thanks for your help.
Pic 1Pic 1
chjpcoi
Hi @Rafal.Gaweda
Can you help me? please!
Stephane.kapetanovic
hi @chjpcoi
Public ViewMngr As IRobotViewMngr
Sub create_view_from_selection()
    Dim Robapp As IRobotApplication
    Set Robapp = New RobotApplication
    Set ViewMngr = Robapp.Project.ViewMngr
    Dim ActiveView As RobotView
    Set ActiveView = ViewMngr.GetView(ActiveViewNumber)
    Dim CurrentType As IRobotViewType
    CurrentType = ActiveView.Type
    Dim View As IRobotView3
    Set View = ViewMngr.CreateView(CurrentType)
        View.Projection = ActiveView.Projection
        ' Possible to Add more parameters as view setting or display
    Dim RSel As RobotSelection
    Dim TypeSel As IRobotObjectType
    Tb_Type = Array(IRobotObjectType.I_OT_NODE, _
                    IRobotObjectType.I_OT_BAR, _
                    IRobotObjectType.I_OT_GEOMETRY, _
                    IRobotObjectType.I_OT_OBJECT, _
                    IRobotObjectType.I_OT_PANEL, _
                    IRobotObjectType.I_OT_FINITE_ELEMENT)
    ' Possible to limit or Add more selection type
    For i = LBound(Tb_Type) To UBound(Tb_Type)
      TypeSel = Tb_Type(i)
      Set RSel = Robapp.Project.Structure.Selections.Get(TypeSel)
      View.Selection.Set TypeSel, RSel
    Next i
    View.Visible = True
    View.Redraw (0)
    Robapp.Project.ViewMngr.Refresh
    View.Window.Activate
    Set Robapp = Nothing
End Sub
Function ActiveViewNumber()
   For i = 1 To ViewMngr.ViewCount
     If ViewMngr.GetView(i).Window.IsActive <> 0 Then
       ActiveViewNumber = i: Exit Function
   Next i
End Function
See also
https://forums.autodesk.com/t5/robot-structural-analysis-forum/view-with-isolated-elements-via-ros-a...
chjpcoi
Hi @Stephane.kapetanovic
Thank for your help.
Type a product name
