(API) Modal Analysis Results
I need to export the modal results (frequency and Eigen Vector, see in picture attached) for Excel by API. Is this possible? I already see in the forum, but i cant find any information about this.
regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dim RDD As RobotDisplacementData
Dim Nodes  As RobotNodeServer
Dim RES As RobotEigenvectorsServer
Dim REV As RobotEigenvaluesServer
Set Nodes = RobApp.Project.Structure.Nodes
Set RES = RobApp.Project.Structure.Results.Advanced.Eigenvectors
Set REV = RobApp.Project.Structure.Results.Advanced.Eigenvalues
Modalcase = 3
NModes = RobApp.Project.Structure.Cases.Get(Modalcase).ModesCount
row = 1
For I = 1 To Nodes.GetAll.Count
    NodeNumber = Nodes.GetAll.Get(I).Number
    For Modenum = 1 To NModes
        Set RDD = RES.Value(NodeNumber, Modalcase, Modenum)
        Cells(row, 1) = Str(NodeNumber) + " / " + Str(Modalcase) + " / " + Str(Modenum)
        Cells(row, 2) = REV.Value(Modalcase, Modenum).Frequence
        Cells(row, 3) = RDD.UX
        Cells(row, 4) = RDD.UY
        Cells(row, 5) = RDD.UZ
        row = row + 1
    Next Modenum
Next I
Rafal Gaweda
Thank you Rafal, i'll test the code!! 😄
I have one more question, when i have my model calculated and i change one section, for example, appear a messange box that will change the results (img attch), is there anyway to put "yes" automatically or do something for this message dont appear?
regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal,
I have an error in this line of code:
I see that in code you dont Dim the variable "NModes" so i do:
Dim NModes as RobotCaseServer
But i still have the same error, so i saw that i dont have the option ".ModesCount", after the ".Get(Modalcase)
what is wrong?
oh, i already figure it out, its "NModes = RobApp.Project.Structure.Cases.GetCmpntCount(Modalcase)" 😄 thank you anyway 😄
