(API) Macro - Get Reactions
RRufino
Message 1 of 8
RRufino
Dear all,
I was looking to previous macros developed by Rafal and other users to get forces tables, which in that time i've customized some of that to my personal use (little layout changes)
Now i was attempting to make similar macro but to get reactions....unfortunately my programming skills are poor so i ask if anybody can give me some help, i think this macro will be helpful to many users.
Thanks in advance,
RR
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 8
RRufino
Hi Rafal,
I was hoping you to read this. I already saw that topic but it seems very different from "forces tables macro", because the one  on topic you said reads robot tables avoiding csv exportation and the one i was get inspiration generates tables (please see attachment).
RR
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Oh, you want me to make this macro....
You will owe me Port-wine (also known as Vinho do Porto) from Porto (the original one:-))
Rafal Gaweda
Message 5 of 8
RRufino
You catched me! Will be my pleasure i think somewhere in the past i already said this to you. Instead i will offer you other one nearest from where i live...Ginga a.k.a. Ginginha, do you know it? Send me your adress by private message and i'll give you news 😉
RR
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have fun 🙂
Rafal Gaweda
Message 7 of 8
RRufino
Oh man, you are the one, not Mourinho! 😉
Thanks a lot Rafal, please don't forget to send me your adress.
Message 8 of 8
Hello Rafal,
Thank you very much for all your help !
I can't find a way to implement "nodes' conditions limits" in VBA (sorry for the english). I would like a macro that checks for the nodes conditions to find which nodes are fixed.
Indeed, I did a macro to extract reactions from several RSA files but this macro requires the fixed nodes numbers as inputs. However these fixed nodes numbers might change and the purpose of the macro is that I don't need to open all the files. I've found a function called "isfixed" that might correspond but I don't know how to use it and it wouldn't help for definition of such limit.
Btw, I've seen many addins instead of macro. Is there a way to see the code of all these .exe files or these are just black boxes ?
Thank you for your time
