(API) macro for updating panel contour loads from Excel
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
First import contour loads (automatically for all simple cases)
Then you can change values in Px1..Pz3 columns, and X Y Z columns and run Update
Do not make any change in Case, Record, Object List or Number of contour points columns (or modify macro by your own to consider these or other changes you want)
Rafal Gaweda
Replies (27)
Message 21 of 28
That's what I did but the warning remains.
The file attached to this message is my excel-vba file. load case : line 170 .
Can you please help me finding what i'm missing?
Message 22 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I do not see any problem.
Line 170 is either empty or as comment ,depending on which line is line 1.
Rafal Gaweda
Message 23 of 28
Please try to lunch the program et and then lunch the calculs to see.
I see no error from line 170 to line 208(laod case "longine") but still i got a warning for that load
Message 24 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Local vector for contour must be set using SetVector() function
ex.
LoadRecCont.SetPoint 1, 0, donnee3, haut
LoadRecCont.SetPoint 2, 3, 1 + donnee3, haut
LoadRecCont.SetPoint 3, 3, 1 + donnee3 + donnee4, haut
LoadRecCont.SetVector 0, 0, 1
Rafal Gaweda
Message 25 of 28
neeraj.khatri
I am trying to use API for contour load modification,  I used Getcontourloads tab to get contour load data which is till row 551 in excel.
I am trying to add a new load by copying rows 547-551 to 552-555 and modifying Record (column B), Pz1 (column F) and X,Y,Z values. When I run Update_Loads tab it gives a runtime error. Can you please help? I am attaching a screenshot..
Message 26 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @neeraj.khatri
This macro updates ONLY imported loads.
You need to modify it by adding some code to create load records.
Rafal Gaweda
Message 27 of 28
NNBL
I want to change the coordinate also along with contour definition.  Any VBA marco for it?
Message 28 of 28
tangld500
Very useful. Thank you!
