(API) macro for detecting short calculation elements - Instability type 3
1. Select all model (CTRL+A) and run intersection (Edit > Intersect)
2. Find the shorter bars and determine why their end nodes are in such locations
This is an old thread, but a new question crossed my mind.
Rather than using the workaround above, would it be possible to read lengths of calculation elements using API?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Attached example macro.
Set length limit, run macro, nodes selection will be automatically made in Robot.
Rafal Gaweda
Wow, this is great, thanks Rafal!
Rafal.Gaweda
Autodesk Support
Autodesk Support
UPdate 1 🙂 - only short calc  element listed.
Rafal Gaweda
athurD
Hi. You can explanation help me???
Tool is used to doing????????
I am still not understood. thanks
Rafal.Gaweda
Autodesk Support
Autodesk Support
"macro for detecting short calculation elements" which can be the reasons of "Instability type 3" while running model calculations.
Rafal Gaweda
