(API) How to create code design groups?
seifehab_bl4
seifehab_bl4
I'm looking to create a script in C# and want to be able to create code design groups and specify which bar IDs go into each group, so that I can do a code group design later. I found an excel macro script on this forum that can edit existing code groups, but I want to be able to create new ones, and would prefer if it was in C# if possible, please. I tried searching through the documentation but couldn't find anything about code groups.
@Rafal.Gaweda would appreciate any help.
Rafal.Gaweda
Autodesk Support
Autodesk Support
seifehab_bl4
Hi @Rafal.Gaweda
Thank you for sharing this. I looked through the code there and identified the function I've attached as an image. From looking at the RobotOM assembly file, I was able to convert it to C# like in the other attached image. I'm not getting any errors, but the new group doesn't show up in the robot model. Would you happen to know why please? I have no experience writing VBA and am unfamiliar with it.
seifehab_bl4
Managed to figure it out in the end. Attached the finished code for reference. Forgot to initialise codeGroupNum in the screenshot I sent.
Stephane.kapetanovic
hi @bhuttomehran33
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
