(API) Geting Required Reinforcement on panels
What is the way to get Required Reinforcement values on panels from API?
robapp.Project.Structure.Results ... ???
Rafal.Gaweda
Autodesk Support
Autodesk Support
Public Sub CommandButton1_Click()
Dim RobApp = New RobotApplication
Dim FeReinRes As RobotFeResultReinforcement
row = 10
For i = 1 To 24
    Set FeReinRes = RobApp.Project.Structure.Results.FiniteElems.Reinforcement(i)
    Cells(row, 2) = FeReinRes.AX_BOTTOM * 10000
    Cells(row, 3) = FeReinRes.AX_TOP * 10000
    Cells(row, 4) = FeReinRes.AY_BOTTOM * 10000
    Cells(row, 5) = FeReinRes.AY_TOP * 10000
    row = row + 1
Next i
End Sub
Rafal Gaweda
As I understand,
robapp.Project.Structure.Results.FiniteElems.Reinforcement() -> expects an integer (node number)
however it doesn't work.
RobotSelection NodeSelection = robApp.Project.Structure.Selections.CreateFull(IRobotObjectType.I_OT_NODE); // Select Nodes
IRobotCollection NodeCollection = (IRobotCollection)robApp.Project.Structure.Nodes.GetMany(NodeSelection); // Collect Nodes
for (int i = 1; i <= NodeCollection.Count; i++)
RobotNode RN = NodeCollection.Get(i); var FeRein = (RobotFeResultReinforcement)robApp.Project.Structure.Results.FiniteElems.Reinforcement(RN.Number); double asax = FeRein.AX_BOTTOM * 1000; double asay = FeRein.AY_BOTTOM * 1000; double asux = FeRein.AX_TOP * 1000; double asuy = FeRein.AY_TOP * 1000; }
this doesn't work.
all values are 0.0
Rafal.Gaweda
Autodesk Support
Autodesk Support
No
robApp.Project.Structure.Results.FiniteElems.Reinforcement(FE.Number)
or
robApp.Project.Structure.Results.FiniteElems.Reinforcement(FE.Number, Node.Number)
Rafal Gaweda
No. Its not working that way!
One should provide the panel number together with the node number, instead of FE number.
Check out the image!
So the correct way is:
robApp.Project.Structure.Results.FiniteElems.Reinforcement(Panel.Number, Node.Number)
