API - Get all connected bars by node
Xyz_Zyx
Xyz_Zyx
How to get all connected bars by node if the selected node is not start/end node of any bar?
Please see attached picture.
- When I select node 6 and click Select Adjoining Bars/Objects --> Result is bars: 1,3 and nodes 1,2,5,6 (This is what I'm trying to achieve)
- When I use NodeServer.GetConnectedBars("6") --> Result is bar 3
  - What should I do that the result would be 1 and 3
I tried to tweak the code which is for panels, but could't get nodelist from bars.
http://forums.autodesk.com/t5/robot-structural-analysis/api-robot-api-compatibility-between-robot-20...
-Ofa
Rafal.Gaweda
Autodesk Support
Autodesk Support
You have to run Model Generation then check bar calculation elements of bars (RobotBar.Elements) and their nodes too.
See project files here:
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-for-short-calculation-elements-det...
as an example
Rafal Gaweda
Xyz_Zyx
Got it!
Thank you very much, once again.
-Ofa
