Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
As there's no implicit option in Robot to export reactions to Microsoft Excel (.xlsx format), only (.csv) format
this addin will export reactions to Excel
see the file in attachments.
Hi everyone,
there is some issue in the API.
the columns of table don't show the correct value, to a little test it happen that in FX column I have "CQC" and all the values shift in the next column. To have a clearest focus on this topic show the image below:
However, this is a very nice tool.
Greetings
Thanks for the feedback.
a small change to fix such a problem (the name of the load combination contains "/" in it, please tell me if the problem still exists.
Small macro doing that ,attached
(if it is not properly open in Excel, open VBA editor and play with changing separators characters, relevant code marked in macro)
Dear, all
First of all, great thanks for efforts.
How can i select one case and export its reactions to excel only ? The default is to export all cases!
Please see the modified version https://forums.autodesk.com/t5/robot-structural-analysis-forum/addin-for-exporting-reactions-to-exce...
